Activity Forums Adobe After Effects Expressions convert value increase to decrease
  • convert value increase to decrease
    Posted by David Wiffen on January 24, 2011 at 10:44 am
    Hi Everyone,
    I have a null scale value increasing from 100% to 700%.
    All i want to do is pickwhip the value and turn the value around so 100% = 100% and 700% = 25%.
    So basically as the driver null increases in size another driven null decreases with the ability to adjust the value ranges.
    Many thanks for any help!!
    David Wiffen replied 15 years, 7 months ago 3 Members · 3 Replies
  • Darren Chappell
    January 24, 2011 at 1:14 pm
    Will the following expression work . .
    linear(value,a,b,c,d)
    a=your observed min val
    b=your observed max val
    c=your proposed min val
    d=your proposed max val
    therefore, this should be good for you = linear(value,100,700,100,25)
  • Dan Ebberts
    January 24, 2011 at 4:18 pm
    Assuming that your layers are 2D and uniformly scaled, this should work:
    s = thisComp.layer(“Null 1”).transform.scale[0];
    linear(s,100,700,[100,100],[25,25])
    Dan
  • David Wiffen
    January 24, 2011 at 5:36 pm
    thanks guys – will give it a try and post back 🙂
