Activity Forums Adobe After Effects convert text to shop for amx export
  • convert text to shop for amx export
    Posted by Todd Morgan on June 10, 2007 at 5:17 pm
    I am using ae6.51 and when i export my comp to amx for livemotion none of my text makes it through. any one have a work around? i have completed a huge project and don’t not wish to have to redo all type keyframing. is there a plug-in that converts type to shape/outline right in the comp conserving all animation?
    thanks!
    t
    Roland R. kahlenberg replied 19 years, 3 months ago 2 Members · 1 Reply
  • Roland R. kahlenberg
    June 10, 2007 at 6:59 pm
    Download the tryout version of AE7 and see if the Create Outline feature works for you. This feature works with the Text tool, so you’ll need to re-input your text. Depending on how you animated your text, a simple copy-paste routine will make the transition less painful.
    HTH
    Roland Kahlenberg
    https://www.broadcastGEMs.com – Adobe After Effects project files
    https://www.myspace.com/rorkrgbspace
