Activity Forums Compression Techniques Convert single large .ts mpeg-ts h264 file to m3u8
  • Convert single large .ts mpeg-ts h264 file to m3u8
    Posted by Sarada Sahoo on August 2, 2016 at 8:04 pm
    i have single .ts file, which is large. Roku does not have feature to play such big file. it always tries to download full file before playing. and also RoKu does not support EXTINF HLS4 discontinuity option.
    So, i need to write in m3u8 with minimum 3 .ts files.
    I was trying to convert but download is failing with all options i tried for ffmpeg.
    Could you please help how can i play this in roku or how can i convert this to m3u8.
    Error below.
    ./ffmpeg -re -i https://ns3045782.ip-5-135-142.eu:8000/live/sYKADDaJs2/SnoQc6v4hZ/3900.ts -c copy chunklist.m3u8 -headers ‘User-Agent: “FMLE/3.0 (compatible; FMSc/1.0)”‘
    ffmpeg version N-63893-gc69defd Copyright (c) 2000-2014 the FFmpeg developers
    built on Jul 16 2014 05:38:01 with gcc 4.6 (Debian 4.6.3-1)
    configuration: –prefix=/root/ffmpeg-static/64bit –extra-cflags=’-I/root/ffmpeg-static/64bit/include -static’ –extra-ldflags=’-L/root/ffmpeg-static/64bit/lib -static’ –extra-libs=’-lxml2 -lexpat -lfreetype’ –enable-static –disable-shared –disable-ffserver –disable-doc –enable-bzlib –enable-zlib –enable-postproc –enable-runtime-cpudetect –enable-libx264 –enable-gpl –enable-libtheora –enable-libvorbis –enable-libmp3lame –enable-gray –enable-libass –enable-libfreetype –enable-libopenjpeg –enable-libspeex –enable-libvo-aacenc –enable-libvo-amrwbenc –enable-version3 –enable-libvpx
    libavutil 52. 89.100 / 52. 89.100
    libavcodec 55. 66.101 / 55. 66.101
    libavformat 55. 43.100 / 55. 43.100
    libavdevice 55. 13.101 / 55. 13.101
    libavfilter 4. 8.100 / 4. 8.100
    libswscale 2. 6.100 / 2. 6.100
    libswresample 0. 19.100 / 0. 19.100
    libpostproc 52. 3.100 / 52. 3.100
    Trailing options were found on the commandline.
    Input #0, mpegts, from ‘https://ns3045782.ip-5-135-142.eu:8000/live/sYKADDaJs2/SnoQc6v4hZ/3900.ts’:
    Duration: N/A, start: 37562.820100, bitrate: 179 kb/s
    Program 1
    Metadata:
    service_name : Service01
    service_provider: FFmpeg
    Stream #0:0[0x100]: Video: h264 (Main) ([27][0][0][0] / 0x001B), yuv420p, 1280×720 [SAR 1:1 DAR 16:9], 25 fps, 25 tbr, 90k tbn, 50 tbc
    Stream #0:1[0x101]: Audio: aac ([15][0][0][0] / 0x000F), 44100 Hz, stereo, fltp, 179 kb/s
    Output #0, hls, to ‘chunklist.m3u8’:
    Metadata:
    encoder : Lavf55.43.100
    Stream #0:0: Video: h264 ([27][0][0][0] / 0x001B), yuv420p, 1280×720 [SAR 1:1 DAR 16:9], q=2-31, 25 fps, 90k tbn, 25 tbc
    Stream #0:1: Audio: aac ([15][0][0][0] / 0x000F), 44100 Hz, stereo, 179 kb/s
    Stream mapping:
    Stream #0:0 -> #0:0 (copy)
    Stream #0:1 -> #0:1 (copy)
    Press [q] to stop, [?] for help
    frame= 700 fps= 25 q=-1.0 Lsize=N/A time=00:00:28.00 bitrate=N/A
    video:5604kB audio:444kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: unknown
    Sarada Sahoo replied 9 years, 11 months ago 1 Member · 0 Replies
  • 0 Replies
