Activity › Forums › Adobe Premiere Pro › Convert RGB to YUV ( Channel Combiner Effect ) in Premiere Pro
  • Convert RGB to YUV ( Channel Combiner Effect ) in Premiere Pro
    Posted by Anmol Mishra on January 28, 2018 at 9:57 am
    Is there an equivalent effect or series of effects that wil map RGV to YUV inside Premiere Pro ?
    As an example Channel Combiner does Effect > Channel > Channel Combiner RGB to YUV inside After Effects.
    Anmol Mishra replied 8 years, 8 months ago 1 Member · 2 Replies
  • Anmol Mishra
    January 30, 2018 at 10:47 am
    I want to change the file to YUV space. So RGB now maps to YUV, Red is now Y channel.
    I want a transformation on separate YUV channels, and then convert them back to RGB.
  • Anmol Mishra
    February 1, 2018 at 12:02 pm
    You asked me What not Why.
    However, I generally use a UV blur on my footage before using it further. And there is no way, per my knowledge that I can do it outside AE.
