Activity Forums Adobe After Effects Expressions Convert pre-comp time
  • Convert pre-comp time
    Posted by Gus Favoreto on February 11, 2019 at 7:58 pm
    Hi guys,
    I am using a simple Slider-Control to animate some number from 0 to 100, that goes back and forth several times. But now the numbers are in vector, like manually design and I can use a type to to the animation.
    My question is, how can I change the Time-remap for the precomp (like 30fps) to control with a slider from 0-100?
    My ideia is add each number to a frame, so I will have 100 frames inside of the pre-comp.
    Thank you so much!
    Gus
    Gus Favoreto replied 7 years, 7 months ago 1 Member · 1 Reply
