Activity Forums Apple Final Cut Pro Legacy Convert NTSC to PAL
  • Convert NTSC to PAL
    Posted by Sue Lawson on June 30, 2008 at 5:20 am
    Hi all.
    Client would like me to create a PAL DVD for him of his feature-length project. Currently, the project is NTSC, SD, 29.97. On previous projects, I’ve used the Standards Converter for FCP from Nattress (love his plug-ins and filters!) with great success. However, that was just a single clip here and there.
    Am I able to export the entire 2-hour NTSC timeline as a QT movie, bring it back into the project, drop it into a PAL sequence, nest it as a single clip, apply the Standards Converter to the “single-clip” in the PAL sequence and then drop the *original* (i.e. the QT movie) into the image well?
    Will this work?
    … and if so, do I need to make the QT movie self-contained, or can I use a reference movie?
    … or, am I better off doing the entire standards conversion in Compressor or Episode?
    Thanks in advance for the guidance!
    — Sue
    Dual 2.7 GHz PowerPC G5
    2.5 GB DDR SDRAM
    GFX: ATI Radeon 9650
    Mac OS 10.4.11
    Final Cut Studio 2
    FCP 6.0.3 Compressor 3.0.3 Soundtrack Pro 2.0.2 Motion 3.0.2 DVDSP 4.2.1
    Sue Lawson replied 18 years, 2 months ago 4 Members · 4 Replies
  • Gary Adcock
    June 30, 2008 at 1:06 pm
    [Sue Lawson] “… and if so, do I need to make the QT movie self-contained, or can I use a reference movie? “
    Self contained will always work better here, then the power is being used to process rather than re-rendering.
    “… or, am I better off doing the entire standards conversion in Compressor or Episode? “
    For a single DVD — Episode / Compressor will allow for multiple CPU’s to be used- nattress /FCP will only use what FCP allows.
    gary adcock
    Studio37
    HD & Film Consultation
    Post and Production Workflows
    Inside look at the IoHD
  • Steve Eisen
    June 30, 2008 at 1:09 pm
    Sue
    Check out Walter’s response above.
    Hardware will give you the best quality.
    Steve Eisen
    Eisen Video Productions
    Board of Directors
    Chicago Final Cut Pro Users Group
  • Walter Biscardi
    June 30, 2008 at 1:11 pm
    [Sue Lawson] “Am I able to export the entire 2-hour NTSC timeline as a QT movie, bring it back into the project, drop it into a PAL sequence, nest it as a single clip, apply the Standards Converter to the “single-clip” in the PAL sequence and then drop the *original* (i.e. the QT movie) into the image well?”
    This will not work as you will essentially get a flash frame on every edit. Nattress even warns you about this in the instructions. Each cut edit will essentially split the screen in half for one frame creating a flash frame. We have seen this here when we tried it.
    Master the show off to tape or a self contained quicktime and take it to a post house that can perform this conversion for you. We send all our NTSC material to PostWorks in New York for PAL conversion. They handle both SD and HD at a very reasonable price.
    Walter Biscardi, Jr.
    Biscardi Creative Media
    HD and SD Production for Broadcast and Independent Productions.
    STOP STARING AND START GRADING WITH APPLE COLOR Apple Color Training DVD available now!
    Read my Blog!
    View Walter Biscardi's profile on LinkedIn
  • Sue Lawson
    June 30, 2008 at 3:05 pm
    Thanks guys!
    — Sue
    2.5 GB DDR SDRAM
    Mac OS 10.4.11
    Final Cut Studio 2
