Activity Forums Adobe After Effects Convert mov
  • Convert mov
    Posted by Hugo Garcia on January 4, 2010 at 4:51 am
    Hi
    I made an animation for a mural in After Effects with a size of 1400×2000, The problem is I need that this composition is in a format either .Mpeg2, .Avi or wmv. Trying to publish the movie on AE as instead of mov Mpeg2, I mark error… Plugin plugin aegp e / s half: The combination of frame size… Etc. I tried with compressor but the extension is not whether .Mpeg2, But if another and seek not want compression will want as close as possible. Xilisoft converter lowered but sizes are not well. There any way I can make this conversion while respecting the original???
    Thanx…
    Hugo Garcia replied 16 years, 8 months ago 2 Members · 3 Replies
  • Bartek Skorupa
    January 4, 2010 at 10:17 am
    The extension of mpeg2 is mpg or mpeg.
    This will still be mpeg2.
    You said you tried compressor, so I assume you use Mac.
    On Mac you can render mpeg2 straight from AE.
    wmv is a problem, avi also, despite we have the option to export avi.
    Bartek Skorupa
    Warszawa, Poland
  • Hugo Garcia
    January 4, 2010 at 8:07 pm
    Yes actually I am aware that it is a very old dimension or size, it is for a mural or wall where other animations have been played before, is very very big and the equipment they use to play the animation is some sort of comverter that doesn’t receive .mov, I tried to process the movie or animation staight from AE in MPEG2 but it mentioned an error, the one i’ve written in the previous post…
  • Hugo Garcia
    January 4, 2010 at 10:55 pm
    Yes, will try that, they hired an outsource artist to do it, but I try to contact him, thanx for your help!
