Activity Forums Apple Final Cut Pro Legacy Convert .MOV file (15-20 GB) to .MXF file ???
  • Convert .MOV file (15-20 GB) to .MXF file ???
    Posted by Kim Manis on October 30, 2015 at 9:13 am
    Hello Guys, I’m pretty new to this editing career and I need some help.. T T
    I’ve got H.264 footages from DSLR camera and I recompressed them to Apple pro res 422 LT for editing with final cut pro 7. with this sequence setting:
    Then I need this following output:
    Video Codec: XDCAM HD 422 50mbps 1920x1080i @25fps
    Audio Codec: 8 channels 24bits PCM
    Wrapper: .MXF
    What is the best way the get this outcome with the accurate codec and vdo quality?
    Thank you very much..
    Kim Manis replied 10 years, 10 months ago 2 Members · 2 Replies
  • Shane Ross
    October 30, 2015 at 5:30 pm
    First off, you need to have your audio mixed and laid out on the timeline properly. Meaning what’s required as the audio deliverable be mixed and exported as 8 audio STEMS. Put those 8 STEMS on the timeline, go into the Sequence Settings, AUDIO tab. Make the output 8 channels…all DUAL MONO.
    Then go to the FILE menu, EXPORT…SONY XDCAM.
    Shane
    Little Frog Post
  • Kim Manis
    November 2, 2015 at 9:51 am
    Thank you very much Shane Ross. I will try with your advice and i’ll let you know the result.
    Cheers!
    Kim
