Activity Forums Adobe After Effects Convert Frame Size OF 720 x 576 FOR 720 x 480 in After Effects
  • Convert Frame Size OF 720 x 576 FOR 720 x 480 in After Effects
    Posted by Marcelo on May 18, 2005 at 1:51 pm
    How I make to convert the frame size of 720 x 576 for 720 x 480 into the video that I captured? This video was filmed in the PAL.
    Marcelo replied 21 years, 3 months ago 2 Members · 2 Replies
  • Filip Vandueren
    May 18, 2005 at 2:39 pm
    • Make sure your PAL footage is interpreted with the right Pixel aspect ratio.
      A 720*576 file can be either D1/DV Pal or D1/DV Pal Widescreen
    • Create a new composition with the NTSC DV preset, again this can also be NSTC DV widescreen
    • Drop your footage in the comp and then use one of these keystrokes:
      Command-Alt-Shift-G -> this will make the video as high as the comp (there may be a few black pixels left & right)
      or
      Command-Alt-Shift-H -> this will make the video as wide as the comp (a few pixels up and down are lost)
      BTW: thats control, not command if you’re on PC
    • There is also the issue of frame-rate, you’re going from a 25 to 29.97 fps standard.
      If you can get away with a slight-speedchange, I would interpret the footage as 24 fps, set the comp to 24 fps and then render using pulldown.
      There are several other ways, try doing a search on NTSC PAL conversion
  • Marcelo
    May 19, 2005 at 5:16 pm
    Filip,
    Special thanks !
