Activity Forums Adobe After Effects Expressions convert expression to keyframes in afx7 – can’t get it to work
  • convert expression to keyframes in afx7 – can’t get it to work
    Posted by Scott G on December 22, 2006 at 4:15 am
    in 6.5 i just select the property, right click on the layer, and choose convert expression to keyframes from the keyframe assistant menu.
    in afx7 i highlight the property, say, position, then right click on the layer and go to keyframe assistant… convert is always grayed out! it looks like right-clicking UNhighlights the property.
    how do you do this in v7? v7 is driving me insane with its useless usability!!
    Cowdog replied 19 years, 9 months ago 3 Members · 2 Replies
  • Julian Sixx
    December 22, 2006 at 6:16 am
    Hi
    highlight the property=>go to Keyframe Assistant=>Comvert Expression to KF.
  • Cowdog
    December 22, 2006 at 5:03 pm
    Scott,
    Number One: When you go off like a dock worker cussin’ and swearin’ and carryin’ on with a mouth to peel the paint off the walls, you are going to get bitten by the Dog.
    Also, when I tried to write you about your recent tirade, your email bounced and so your account has been deactivated.
    Sign up for a real one.
    Yer pal,
    Cowdog
