Activity Forums Apple Final Cut Pro Legacy Convert clips for multicamera editing
  • Convert clips for multicamera editing
    Posted by Karl Bergvall on June 1, 2013 at 8:30 pm
    If I have two clips with different size (ex. one is 720×560 and another 1280×720) multicamera editing is impossible.
    Final Cut does not convert the clips.
    Is there some way to convert them into the same size?
    Shane Ross replied 13 years, 3 months ago 2 Members · 3 Replies
  • Shane Ross
    June 1, 2013 at 11:40 pm
    It’s not only size…they have to be the same size, frame rate, and codec.
    What format are the clips now? Where do they come from?
    You can use Compressor to do the conversion.
    Shane
    Little Frog Post
  • Karl Bergvall
    June 2, 2013 at 11:05 am
    The clips comes from two different cameras. Now they are 760×520 and 1280×720.
  • Shane Ross
    June 2, 2013 at 7:27 pm
    Leaving out vital information… what cameras? What format were they shot…P2, DV, XDCAM, HDV? What frame rate? How did you ingest them into the system?
    Shane
    Little Frog Post
