Activity Forums Adobe After Effects Convert audio to keyframes then select all those below a given value ?
  • Convert audio to keyframes then select all those below a given value ?
    Posted by Peter Dexter on March 10, 2014 at 9:50 pm
    HI
    Just wondering here if there was a method by which one could select keyframes of a property by their value.
    Similar to selecting ‘of equal value’ but instead to select all keyframes below lets say a value of 20.
    I am looking to use ‘Audio to keyframes’ and then tweak my resulting keyframes.
    The returned values are all rather close.. from around 14 – 29 and each is different 29.1342 or 29.1346 so so it would be nice to create an on and off type result using those key frames. I know sound keys does something similar but just wondered if there was a way to ‘cheat’ that in AE.
    To sum up. I want to be able to change all the keyframe values that are higher than 20 to a chosen value and all those above 20 to another chosen value.
    Hope that makes sense and thanks in advance for any help 🙂
    We spent all the budget on doughnuts and now we have no money to make our film.
    Roland R. kahlenberg replied 12 years, 5 months ago 3 Members · 6 Replies
  • Walter Soyka
    March 11, 2014 at 12:03 am
    This is very easy with an expression.
    Alt-click the stopwatch for the property with the keyframes (such as Both Channels) and enter the following expression:
    if (value > 20) 100 else 0;
    Walter Soyka
  • Peter Dexter
    March 11, 2014 at 8:54 am
    Thanks a lot. It is indeed simple and elegant.
  • Peter Dexter
    March 11, 2014 at 9:24 am
    Thanks again that is great. Just one little thing. I used action script 2 years ago quite a bit so it is all rather vague these days. I am sure that I can use that little snippet and tweak it.
    I want to use it with a slider and an existing expression.
    I have this on my slider: effect(“Both Channels”)(1)
    and this on my opacity property: thisComp.layer(“Audio Amplitude”).effect(“Both Channels”)(“Slider”)
    If you had an example how to integrate the: If (value > 20) 100 else 0:
    In either of those lines it would be great.
    Also to extend the if else so that: if greater than twenty but less than twenty five 100 if greater than 25 80 else 0
    That would make my day. I think I could roll from there and then find a good basic expressions page somewhere to embeish.
    Expressions are addictive 🙂
  • Roland R. kahlenberg
    March 11, 2014 at 10:02 am
    This should do it –
    propVal = thisComp.layer("Audio Amplitude").effect("Both Channels")("Slider");
    if (propVal > 25) {
    80
    } else if (propVal > 20 && propVal < 25) {
    100
    } else {
    0
    I’ve found this URL a good resource for Javascript Conditionals – https://stackoverflow.com/questions/253030/best-way-to-format-if-statement-with-multiple-conditions.
    https://www.w3schools.com/ is also good.
    HTH
    RoRK
    Latest AE Workshop – MoGraph Intensity – Shapes & Text
    Intensive mocha & AE Training in Singapore and Other Dangerous Locations
    Imagineer Systems (mocha) Certified Instructor
    & Adobe After Effects CS6 ACE/ACI
  • Peter Dexter
    March 11, 2014 at 9:41 pm
    Thanks very much.
    I will for sure make a visit to the site mentioned
    March 12, 2014 at 12:27 am
    I’ve just realized that there is an issue with the script if the referenced value is at exactly 25. Currently, a value of 25, for the referenced property, will result in an opacity value of 0.
    If that is not intended behavior, then add an = sign to either one of the two explicit conditionals in the script – something like this:
    if (propVal >= 25) OR
    (propVal > 20 && propVal <= 25)
    HTH
    RoRK
