Activity Forums Adobe Premiere Pro convert 60p or 30p to 24p but without slowing down the footage
  • convert 60p or 30p to 24p but without slowing down the footage
    Posted by Bill Chen on June 14, 2015 at 2:14 pm
    hi guys
    i saw a few post which show you how to convert into 24p in premiere pro.
    which is interpreted footage into 23.976, then drop it into 24p timeline.
    but the footage becomes slow-mo.
    if i don’t want to slow down the footage just want the normal speed, what other steps should i take?
    changing speed of the clip?? or…?
    i’m using premiere CC
    any advice would be great! thanks
    Bill Chen replied 11 years, 2 months ago 2 Members · 2 Replies
  • Shane Ross
    June 15, 2015 at 8:57 am
    Simply drop the footage into a sequence with the frame rate you want. Pulldown should happen properly.
    Shane
    Little Frog Post
  • Bill Chen
    June 15, 2015 at 9:07 am
    Thanks for your reply.
    So… If I need to drop a 60p footage into a 24p Comp.
    do I need to interpret footage to 24p. Then drop in and speed up to 200%? So the footage becomes normal speed as before? As I don’t want any slow motion.
