Activity › Forums › Adobe Premiere Pro › Convert 601 color space to 709 in CS4 ?
  • Convert 601 color space to 709 in CS4 ?
    Posted by Ninetto Makavejev on August 10, 2010 at 2:15 pm
    Hello,
    I am mastering a HD-Project which contains SD-Material and I have noticed that the blacks in the SD-Material are showing up too light.
    I am not using a calibrated HD-Monitor,but since the SD-Material was already mastered and color-corrected, I didn’t think I would have too much to worry about.
    Now I have learned that HDTV uses 709 color-space vs. 601 for SD.
    Is there a sure-fire way to make this conversion and keep the color values the SD material had originally?
    thanks, Ninetto
    Todd Kopriva replied 16 years, 1 month ago 4 Members · 5 Replies
  • Vince Becquiot
    August 10, 2010 at 11:42 pm
    Hi Ninetto,
    That’s one of the issue going from SD to HD. I don’t know of any tools that will to do that for you in Premiere. We usually do it on the fly, but yes, you will need a calibrated monitor.
    Vince Becquiot
    Kaptis Studios
    San Francisco – Bay Area
  • Todd Kopriva
    August 11, 2010 at 3:46 am
    If you need to convert from one color space to another and you have After Effects, come on over to the After Effects forum, and we can help you over there.
    Technical Support for professional video software
    After Effects Help & Support
    Premiere Pro Help & Support
  • Jeff Brown
    August 11, 2010 at 1:58 pm
    I would check that you don’t have a problem with “setup” being [mistakenly] embedded in the SD material. I could be wrong, but I’m pretty sure digital black is zero in both colorspaces…
    -Jeff
  • Ninetto Makavejev
    August 12, 2010 at 11:00 am
    Thanks much for the advice.
    Over at the AE Forum they have advised the following workflow:
    1)Make sure imported material is interpreted as correct color profile, i.e. in my case I have RGB uncompressed AVIs.
    2) Set up HD Composition with 709 color space and drop material into comp.
    This all almost seems too easy for me, that AE/Adobe is intelligent enough to convert the color space accurately. I will be exporting to blu-ray so only then will I see if the translations really works as almost “auto-pilot”.
    I am aware that sometimes rookie editors ignore the color profiles of projects they export, so I have to verifiy the uncompressed AVIs indeed are Adobe RGB profiles, I have no desire to color corrected all their stuff for free!
    Anyone else have experience with this?
  • Todd Kopriva
    August 12, 2010 at 3:29 pm
    The color management features introduced in After Effects 7 and refined in CS3 and CS4 were created entirely to make this kind of work easy for you (though not for our engineers).
    I’ll check in on the After Effects thread, but the instructions that you recounted are a little off. The gist is this:
    1) Enable color management for the project.
    2) Import your footage, amking sure that it’s interpreted as 601.
    3) Render and export, specifying 709 as the output color space.
    That’s really it.
