Activity Forums Apple Final Cut Pro Legacy Convert 30fps to 29.97fps – Looks ‘wobbly’
  • Convert 30fps to 29.97fps – Looks ‘wobbly’
    Posted by Rosie Walunas on June 4, 2012 at 7:19 pm
    I have some footage I shot way back on the Canon T1i at 1280x720p 30fps. I am editing in HD ProRes at 29.97. I converted the 30fps footage in Compressor using the default ProRes droplet with changes to 1920×1080 and to 29.97. The compressed footage seems to play back ‘wobbly’ and as if the audio does not match the video. If I move through the footage frame by frame, no frames repeat.
    I am using FCP6 on a MacBook Pro. I’ve had a few mild issues with other HD ProRes footage not being able to play back properly because of the graphics card, etc.
    Did I do this conversion correctly?
    If not, what did I miss?
    Thank you kindly!
    Rosie
    Rosie Walunas replied 14 years, 3 months ago 1 Member · 2 Replies
  • Rosie Walunas
    June 8, 2012 at 7:32 pm
    Yes, it is definitely 1280×720 at 30fps – not 29.97.
    So I did this correctly?
    Thank you kindly!
  • Rosie Walunas
    June 8, 2012 at 8:46 pm
    I converted the 1280×720 30fps H.264 footage in Compressor using the default ProRes droplet [specifying the aspect ratio to be 1920×1080 and the frame rate to be 29.97].
    Then imported the clips in FCP.
    Thanks.
