Activity › Forums › Apple Final Cut Pro Legacy › Convert 23.98p to 59.95 1080i
  • Convert 23.98p to 59.95 1080i
    Posted by Ash Stagg on August 29, 2011 at 10:25 pm
    Got a request to convert 23.98 (1080p) footage to 59.95 (1080i) and can’t seem to figure this one out. I’d understand telecine-ing it to 29.97 if it was 59.94, but 59.95 seems slightly tricky.
    Any suggestions?
    Thanks for the help
    Mark Spano replied 15 years, 1 month ago 4 Members · 3 Replies
  • Shane Ross
    August 29, 2011 at 10:31 pm
    1080i59.94 is 29.97fps. Don’t let the number confuse you…I think they do that on purpose. When you see “i” it means INTERLACED, and 2 fields per frame, 59.94 is FIELDS per second…30fps…at 29.97. So you will be converting 23.98 to 29.97.
    There is no such thing as 59.95…that was most likely a typo.
    Shane
  • Chris Tompkins
    59.95 1080i refers to fields, it’s 60 fields a sec. It’s really 29.97 Frames Per Second.
    Chris Tompkins
    Video Atlanta LLC
  • Mark Spano
    August 31, 2011 at 3:00 pm
    to the OP: 59.95 is a typo. There is no 59.95. Only 59.94. Proceed as you were…
