Activity › Forums › Adobe After Effects Expressions › controlling keyframes
Posted by Shahed Naderi on May 21, 2014 at 10:56 pmhello
I have a bunch of keyframes that drives an animation , I need to control the begging of it. tell it when to begins in seconds by using an slider control.
anyone can help with that expression ?Shahed Naderi replied 12 years, 4 months ago 2 Members · 4 Replies -
Darby Edelen
May 22, 2014 at 3:08 amSomething like this should work:
firstKey = key(1).time;
offset = effect("Slider Control")("Slider");
valueAtTime(time + firstKey - offset);Although that will return an error if the property doesn’t have at least 1 keyframe. A try/catch statement could be used to prevent that error:
try{
catch(err){
value;
}Darby Edelen
Shahed Naderi
May 22, 2014 at 8:07 amthat’s working just fine , thank you bro , but what if you have a comped animation – for instance 2 seconds- and you want to offset and play it with expression through the time line ? I mean control the beginning with a slider on another layer.
is it possible ? -
Darby Edelen
May 22, 2014 at 3:56 pmTime remapping is the easiest way to do something like that. In that case an expression would be optional depending on how you want it set up.
Darby Edelen
