Activity Forums Adobe After Effects Expressions Controlling frame by frame time remapping with a dropdown expression control?
  • Controlling frame by frame time remapping with a dropdown expression control?
    Posted by Aaron Jacob on October 14, 2020 at 2:21 am
    I have a ‘lesson card’ precomp with four options of icon, each representing a type of lesson. Within the precomp are four frames, each showing a different icon.
    Doing this manually for each one would be a case of going in and setting the lesson card precomp’s time remapping to 0:00:00:00 for reading, 00:00:00:01 for grammar, 00:00:00:02 for listening and 00:00:00:03 for speaking.
    However, I’d like to make a dropdown expression control to choose which type of lesson each ‘lesson card’ precomp will be.
    I think I’ve figured out the way to write the expression bit for the dropdown (see screenshot) but I can’t find any information on how to use an exact time remapped value as an option (I’ve just put 0, 1, 2 and 3 in the example). See below for my start on it.
    How would I write the equivalent of 00:00:00:01, 00:00:00:02 etc etc (and is the first bit more or less correct)?
    PS I’m aware there’s other ways I could probably do this, but I really want to understand how this works for future stuff!
    dropDownIndex = effect(“Lesson card type”)(“Menu”).value;
    switch ( dropDownIndex )
    case 1: 0;
    break;
    case 2: 1;
    break;
    case 3: 2;
    break;
    default: 3
    Aaron Jacob replied 5 years, 10 months ago 2 Members · 2 Replies
  • Dan Ebberts
    October 14, 2020 at 7:01 am
    This should work:
    dropDownIndex = effect("Lesson card type")("Menu").value;
    framesToTime(dropDownIndex-1);
  • Aaron Jacob
    October 14, 2020 at 3:33 pm
    That worked perfectly… I had no idea about framesToTime!
    Dan you are the absolute best, thank you. It’s so kind of you to help so many people every day.
