Activity Forums Canon DSLR Cameras controlling depth of field
  • controlling depth of field
    Posted by Tim Taylor on February 29, 2012 at 11:26 pm
    I’m using the Canon T2i to shoot interviews, and I like to use a (f1.8) 50mm prime lens to get the background out of focus. Currently I’m using a legacy FD lens with an Zykor adapter, but I find that I have zero control then over the aperture. I think it just operates wide open, and the depth of field is actually too shallow for me.
    Am I missing something? Is there a way so stop it down to get more DoF, or do I have to spring for the EF lens to get all the functionality?
    Tim Taylor, Producer/Editor
    RESolution Media Services, LLC
    Tim Taylor replied 14 years, 5 months ago 2 Members · 4 Replies
  • Bob Dix
    March 4, 2012 at 8:35 am
    You would be better of using , say a 28-135mm f3.5-5.6 IS Canon Lens and no adapters,at say 85mm or 135mm or an EF l series f2.8 25-70 mm Lens at say 70 mm.
    GOOD LUCK !
    Freelance Imaging & Video
    AUSTRALIA
  • Tim Taylor
    March 6, 2012 at 2:00 pm
    I found the answer.
    The adapter has to be all the way in the locked position, or the aperture won’t fire.
  • Bob Dix
    March 8, 2012 at 1:43 am
    AH, I see
    AUSTRALIA
  • Tim Taylor
    March 8, 2012 at 1:00 pm
    Thanks Bob!
    Unfortunately, most of the locations I find myself in don’t have enough room to use the longer lenses. The 50mm works most of the time, and gives me a plenty shallow DOF. (sometimes too shallow, as I mentioned) As for the DF lens, I’m just being cheap about it – the adapter was only $20, while the EF lens is around $100.
