Activity Forums Adobe After Effects Expressions Control value of two keyframes with one slider.
  • Control value of two keyframes with one slider.
    Posted by Fabian Bosman on November 5, 2019 at 2:19 pm
    Hello After Effects masters,
    I’m creating a template in which the end user would be able to adjust a lowerthird to the length of a name he/she wants to use.
    I’ve made a simple in-animation and out animation.
    So this is my setup:
    Keyframe 1: 00:00 (value is 0)
    Keyframe 2: 02:00 (value is defined by the slider)
    Keyframe 3: 04:00 (value is defined by the slider)
    Keyframe 4: 06:00 (value is 0)
    What I want is one slider to control the value of keyframe 2 and 3.
    But it should not create a new keyframe if you adjust the slider, it will only adjust the value of those two keyframes.
    What should be the expression for this?
    I’ve found this expression online but it is not working for my animation.
    I hope someone can help me.
    if (numKeys > 1){
    t1 = key(1).time;
    t2 = key(2).time;
    v1 = [95, 95]; //or if it's 3d [95, 95, 95]
    slider = comp("INPUT").layer("CONTROL").effect("Zoom intensity")("Slider");
    v2 = [slider, slider]; // or [slider,slider,slider] if 3D
    linear((time, t1, t2, v1, v2);
    } else {
    value
    Fabian Bosman replied 6 years, 10 months ago 2 Members · 2 Replies
  • Dan Ebberts
    November 5, 2019 at 3:05 pm
    I think it will be something like this:
    s = thisComp.layer("Control").effect("Your Slider")("Slider");
    t1 = key(1).time;
    t2 = key(2).time;
    t4 = key(4).time;
    if (time > t1 && time < t4)
    value*s/valueAtTime(t2)
    else
    value;
    Dan
  • Fabian Bosman
    November 23, 2019 at 3:50 pm
    Dan, you are da man ☺
    Thank you for the expression, it was exactly what I was looking for.
    I want to understand what is going on in the code and how it works ☺
    Can you explain how I can customize it?
    So for example, I want keyframe 2 and 3 and 5 to look at the slider value.
    How does that work.
    Greetz,
    Fabian
