Activity › Forums › Adobe After Effects Expressions › control text with expression
  • control text with expression
    Posted by Alex Harding on November 28, 2006 at 4:06 pm
    is it possible to create a text layer that updates dynamically via expressions?
    i know how to make number values appear in the comp in this way, using the “numbers” effect, would like to do the same with actual letters
    cheers
    alex
    David Cabestany replied 17 years, 8 months ago 5 Members · 7 Replies
  • 7 Replies
  • Joshua Ferg
    November 28, 2006 at 4:15 pm
    Not sure how you want the changes to occur but you might try a displacement map.
  • Mark
    November 28, 2006 at 4:27 pm
    If the changes are from rando to text, then you don’t need an expression. Add a text animator and use the character offset.
    Mark
  • Mylenium
    November 28, 2006 at 4:41 pm
    Like Mark said – use animators for character value and offset. Unless you need a specific string to appear based on other formulas, there is no point in using expressions at all.
    Mylenium
    [Pour Myl
  • Alex Harding
    November 28, 2006 at 11:47 pm
    sorry, i didnt make it clear,
    i wanted the actual content of the text to be defined via expressions depending on various paramaters related to other elements in the comp
  • Mylenium
    November 29, 2006 at 7:53 am
    And what are those lements? Do you need distance and position readouts? Labeling that moves with other layers? You have to be more specific. There are jsut too many possibilities.
    Mylenium
    [Pour Myl
  • Alex Harding
    November 29, 2006 at 10:57 am
    sorry
    i already have expressions that calculate distance values and values based on rotation of certain objects relative to the camera and so on. i want diferent words to appear based on the conditions defined by the other vaules, i guess using if and else logic.
    i (thanks to this forum) managed to get the number effect to generate a dynamic counter that can display these values in the comp.
    all i really want to know is whether there is a way to control the content of the normal text via expressions; with the numbers one its obvious where to put the expression because the value is keyframable anyway. with the text one i can see no place for the code, though i vaugely remember reading another thread where someone had done it.
    am i on the wrong track altogether?
    thanks for your responses,
    Alex
  • David Cabestany
    January 2, 2009 at 8:44 pm
    add an expression to the source text that is linked to a null object’s position values, if you want the three values (x,y,z) values to be displayed you’ll have to create three null objects with the same coordinates and link three different text objects.
