Activity Forums Apple Final Cut Pro Legacy Control Surface + FCP
  • Control Surface + FCP
    Posted by Asher Lewis on March 31, 2009 at 4:25 am
    Hi All,
    I’m having an odd issue with my Tascam FW 1082 and Final Cut. I’ve got it all set up as a control surface, but when i adjust the levels while the video is playing through the sequence the video starts lagging and eventually audio drops out. If i stop the playhead and restart playing it’s back in sync and playing audio.
    I’ve tried uninstalling and reinstalling fresh, in addition to deleting the control surface in FCP and then re-adding it…any other suggestions? (the tascam is on it’s own firewire bus btw).
    Cheers! and thanx!
    asher.
    Asher Lewis replied 17 years, 5 months ago 3 Members · 5 Replies
  • Michael Gissing
    March 31, 2009 at 4:30 am
    Not sure as I don’t use a control surface, but perhaps it is the writing off lots of keyframes that bogs the system down. There might be a setting to reduce the number of keyframes written from every frame to say every three frames.
    Do you have a grunty Mac & plenty of RAM?
  • Asher Lewis
    March 31, 2009 at 4:35 am
    it’s got plenty of ram, and i’m not even actually keyframing the audio i’m just setting levels for the track
  • Michael Gissing
    March 31, 2009 at 4:39 am
    You might have to talk to Apple and /or Tascam. Sorry I can’t be more helpful. There are others here at the cow, who use the Tascam and might have ideas.
  • Reid Caulfield
    April 13, 2009 at 1:55 am
    Sounds like FW bus overload.Are your media drives running on the same firewire bus? Is this new behavior for this setup? Have drives changed recently for some reason (system crash & restore, new driver install, etc)?
  • Asher Lewis
    April 13, 2009 at 2:03 am
    hey mate,
    thanx for the response. i ended up reinstalling the OS and the problem went away, i’m thinking it may have been a corrupt plugin.
