Activity › Forums › Adobe After Effects Expressions › control slider keyframe with MARKER
Posted by Ehsan Adham on November 28, 2019 at 8:07 pmHi Every one
i have one null layer, it have slider control and it have two keyframe,
how can i control this keyframes with layer marker?
Ehsan Adham replied 6 years, 10 months ago 2 Members · 4 Replies -
Andrei Popa
November 29, 2019 at 6:45 amIf you plan to use it like this, you don’t even need keyframes. This expression will take the values from the markers comments. Just make sure the comments are always a number.
v1 = parseInt(marker.key(1).comment);
v2 = parseInt(marker.key(2).comment);
t1 = marker.key(1).time;
t2 = marker.key(2).time;
(isNaN(v1+v2)) ? value : linear(time,t1,t2,v1,v2);Andrei
My Envato portfolio. -
Ehsan Adham
November 29, 2019 at 12:01 pmTaaaaanks Andrei
Now i have two Question:
1. how can i use this two MARKER like toggle hold keyframe ?
2. i want name this MARKERS to for example clip1, clip2. How can i control the value of MARKERS?Again Tanks My Friend
Andrei Popa
November 29, 2019 at 12:17 pmWhat do you mean use them like toggle hold keyframe? To have the slider the value of first keyframe until it reaches the second and then snap to that value?
And if you want to rename the markers as you please, you can re-create those 2 keyframes and add this expression instead. The values are now taken from the keyframes.
v1 = valueAtTime(key(1).time);
v2 = valueAtTime(key(2).time);
Andrei
Ehsan Adham
November 29, 2019 at 1:25 pmOH MU GOD
TAAAAAAAAANKS ANDREIYES, My mean: For Example Marker “clip1” value is 150 in time 00:01. So i want go to time 00:02 and Marker “clip2”. Now Value should be 200. i don’t want that value be changed between two marker.
Like Toggle Hold Keyframe.Many Tanks My Friend
