Activity Forums Adobe After Effects Expressions Control shapes contents (Group 1 -35) scale with slider
  • Control shapes contents (Group 1 -35) scale with slider
    Posted by Warren Willmott on September 15, 2014 at 5:24 pm
    Okay so this is my first post so please excuse my AE language.
    I basically have close to 300 circle shapes that I need to scale up together, so essentially they each need to scale up and down together.
    I would imagine a slider would be the best way forward.
    The problem is there is alot of layers so it will extremely painful trying to link each layer to the slider.
    So the best solution that I can think of is telling the null(with the slider) to scale shape>content>group 1-250
    I apologise I have been using AE for a few years but only recently started getting into expressions
    Hopefully that makes sense
    Warren Willmott replied 11 years, 11 months ago 3 Members · 4 Replies
  • Dan Ebberts
    September 15, 2014 at 5:35 pm
    Expressions don’t work that way. An expression can’t change anything except the value of the property hosting the expression (the slider, in this case). Each of your circles is going to need an expression referencing the slider. You could do it with a script, but that might not save you any time if this is a one-off.
    Dan
  • Warren Willmott
    September 15, 2014 at 5:50 pm
    Thanks for quick reply Dan, is not possible then to scale the group of shapes without going into each shapes transform> scale?
    Its just there is so many shapes and it will be easier to control with one layer
  • Kevin Camp
    September 15, 2014 at 7:26 pm
    you can write the expression for one circle, then select the scale property of that circle, choose edit>copy expression only, and then select the other 299 circles and choose paste. then all the circles will have the same expression.
    all you need to do is have the slider on a ‘non-circle’ layer, like a null layer.
    Kevin Camp
    Art Director
    KCPQ, KZJO & KRCW
  • Warren Willmott
    September 16, 2014 at 5:17 am
    Thanks Kevin thats exactly what I was needing, LEGEND!!
