Activity Forums Maxon Cinema 4D Control key and Command key recognized as same key
  • Control key and Command key recognized as same key
    Posted by Jacob Mrozek on February 28, 2013 at 7:38 pm
    I am on a Mac, running R13.
    I am trying to just do a simple selection of points and if I select to many or the wrong ones I cannot deselect. I have tried Shift + LMB and Control + LMB and Command + LMB. When I go into customize my shortcuts I try to add Control + LMB to the deselect function, but when I enter it it shows as Command + LMB, and when I enter Command + LMB it shows as the same.
    Its almost as if the program is recognizing command, and control as the same button. Shift will not deselect the points either.
    Jacob Mrozek replied 13 years, 6 months ago 1 Member · 0 Replies
  • 0 Replies
