Activity Forums Adobe After Effects Expressions Control gap time between start and end animation
  • Control gap time between start and end animation
    Posted by Jano Sempere on December 13, 2017 at 11:37 am
    I’m thinking about how to prepare useful template for essential graphics.
    The point is to set 2 keyframes for in animation and 2 keyframes for out, (thinking simple, shape come to center from left) and control the gap when comp is static with a slider in seconds (you can’t keyframe in essential graphics).
    At this point don’t know if work with precomp time remaped or directly with shapes keyframes.
    I wonder if setup with 4 or 3 keyframes.
    Very lost and many questions.
    Thanks.
    Motiongrapher at cinestorm.es
    Jano Sempere replied 8 years, 9 months ago 2 Members · 2 Replies
  • Dan Ebberts
    December 13, 2017 at 4:42 pm
    Something like this should stretch whatever happens between 2nd and next-to-last keyframes (needs 4 keyframes to do anything):
    if (numKeys >= 4){
    ts = effect("Slider Control")("Slider");
    if (time < key(2).time){
    value
    }else if (time < key(2).time+ts){
    t = linear(time,key(2).time,key(2).time+ts,key(2).time,key(numKeys-1).time);
    valueAtTime(t);
    }else{
    t = time - (key(2).time+ts);
    valueAtTime(key(numKeys-1).time+t);
    }else
    value
    Dan
  • Jano Sempere
    December 20, 2017 at 9:18 am
    Thanks Dan,
    It works like a charm, using it in a template for premiere pro, you can set the duration between start animation and end animation with the slider.
    You always rock.
    Thanks.
