Activity Forums Adobe After Effects Expressions Control Animation with markers e.g. IN and OUT and then IN again
  • Control Animation with markers e.g. IN and OUT and then IN again
    Posted by Mateo Baldasare on September 12, 2023 at 7:33 pm
    Hi there! I hope you are well 😃
    I’m trying to achieve the following:
    Use the markers’ comments of a layer to drive the animation and be able to use another marker with the same comment again. For example:
    The camera Zoom begins at a value of 2,000 with the marker IN” and then interpolates to a value of 5,000 when it reaches the marker “OUT”, AND if I add another “IN” marker after that, it should go back to 2,000
    This is what I did but it only animates between the first two markers (which makes sense):
    markerIN = thisLayer.marker.key(“IN”);
    mIN = markerIN.time;
    markerOUT = thisLayer.marker.key(“OUT”);
    <i style=”background-color: var(–bb-content-background-color); font-family: inherit; font-size: inherit; color: var(–bb-body-text-color);”>mOUT= markerOUT.time;
    <i style=”background-color: var(–bb-content-background-color); font-family: inherit; font-size: inherit; color: var(–bb-body-text-color);”>ease(time, mIN, mOUT, 2000, 5000);
    Thank you!
    Brie Clayton replied 2 years, 11 months ago 3 Members · 3 Replies
  • Dan Ebberts
    September 12, 2023 at 8:28 pm
    It will look something like this (although this may not be exactly right depending on what should happen if there are no markers, or other markers besides IN and OUT):
    m = marker;
    v1 = 2000;
    v2 = 5000;
    val = v1;
    if (m.numKeys > 0){
    n = m.nearestKey(time).index;
    if (time < m.key(n).time) n--;
    if (n > 0){
    if (m.key(n).comment == "IN"){
    val = v1;
    if (n < m.numKeys && m.key(n+1).comment == "OUT"){
    val = ease(time,m.key(n).time,m.key(n+1).time,v1,v2);
    }else if (m.key(n).comment == "OUT"){
    val = v2;
    if ( n < m.numKeys && m.key(n+1).comment == "IN"){
    val = ease(time,m.key(n).time,m.key(n+1).time,v2,v1);
    val
  • Mateo Baldasare
    September 12, 2023 at 8:39 pm
    That worked perfectly, Dan, thank you so much 🙏 It was much more complex than I thought it’d be.
  • Brie Clayton
    September 13, 2023 at 6:11 pm
    Thank you for the solve, Dan!
