Activity Forums Adobe After Effects Expressions Control a row of lights(emitters) to rotate together as an array.
  • Control a row of lights(emitters) to rotate together as an array.
    Posted by Max Bretherton on February 7, 2011 at 9:52 pm
    Hi..
    I am using several lights as emitters for Particular – 1 effect using several light emitters named emitter1, 2, 3 etc. each is producing different coloured particles.
    I have used the pick-whip to link the position of each light to the central one so i can control the position and path of the array with the central light. The rest are offset above and blow it along the Y axis by adding .value-[0,50etc,0] at the end of the pickwhip created expression. So i now have a vertical ‘line’ of lights/emitters.
    Now this is where i am struggling – I want the ‘line/array’ to be able twist as it moves. Like if you spread the fingers of your hand and pretend to fly it around like a airplane- neeeaaaw.
    How can i make it so the lights keep their relative position to the central ‘control’ light but can twist and turn as i animate the central ‘control’ light/emitter?
    Make sense…?
    I really need to make this happen asap as its an effect for a big job at work. So i really appreciate any help you can offer.
    My best regards..Max
    Max Bretherton replied 15 years, 7 months ago 2 Members · 2 Replies
  • Dan Ebberts
    February 8, 2011 at 6:30 am
    How about just parenting the lights to a 3D null (instead of using expressions to link them together) and rotating the null?
    Dan
  • Max Bretherton
    February 8, 2011 at 12:05 pm
    Yes Dan…
    Thank you..that is a much simpler way of doing it and its working.
    Thanks for point me in another direction.
    Max
    thanks and my best regards…max
    Creative Director – RTR Productions
