Activity Forums Adobe After Effects Expressions Control a Pre-Comped layers 3D Rotation via 2 Nulls
  • Control a Pre-Comped layers 3D Rotation via 2 Nulls
    Posted by Jesus Suarez on January 6, 2017 at 1:00 am
    Hi everyone.
    I am working on this scene where I have multiple nulls in 3D space and I am connecting lines between those nulls. Up to this point everything works perfect. The problem is that I need to put a Flare on one of those lines and have it follow the line in 3D space.
    So, as I move the nulls the line follows, but the flare does not.
    Note: I need the flare to be inside of a precomp because of the design of it. Attaching the flares position and center position to each null respectively does not work in this case.
    Any help is greatly appreciated!
    Here’s a link to download an AE project file > https://www.dropbox.com/s/r4obl2xocx28s8i/Flare%20help%20scene.aep?dl=0
    Here’s a screenshot of the scene.
    Jesus Suarez replied 9 years, 8 months ago 1 Member · 0 Replies
  • 0 Replies
