Activity Forums VEGAS Pro Contrast is not as advertised in the scopes
  • Contrast is not as advertised in the scopes
    Posted by Philippe Gosselin on June 18, 2012 at 10:47 pm
    Hi all,
    Well now that my MAC to PC problem has been solved, we exported all in QT Animation, I can get on with the project.
    I dropped all files into the timeline and now I am in the process of reapplying the slow-mo effect to my clips, here’s my workflow for that:
    1: I frameserve the clip out of Vegas into an AVS script that does slo-mo
    2: I open the script through VirtualDub and export the clip in a lossless codec, in this case I use Huffyuv.
    3: I re-import the clip, now slow-moded, into Vegas
    Here’s the thing though, even if this is a lossless codec the contrast has changed. In the waveform the whites went to about 85 and they are in the 80.
    Just a minute ago I was scrubbing a clip to make it shorter and I noticed in the preview window that the contrast seemed to have gone back to normal. When I stop scrubbing the contrast was not normal again. Take a look at the screenshots, 01 is for when I am scrubbing and 02 is for when I am not.
    Now if the Huffyuv is not entirely lossless and something happens to the file when I converted it then why does it show the proper (original) contrast when I scrub the clip?
    Thanks for your input
    Phil
    ps, I’ve tried with another lossless codec, this time with Lagarith, and the result is the same.
    Philippe Gosselin replied 14 years, 2 months ago 1 Member · 1 Reply
  • Philippe Gosselin
    June 21, 2012 at 2:29 pm
    Somewhat of an update.
    It dawned on me that this scrubbing effect is very much like when scrubbing through an FX’d event. When I scrub the preview window shos the original video.
    Now I just drop an event on the timeline, this time the original MOV file recorded by my 60D, and guess what, the contrast still is different when I scrub through that event.
    Furthermore, if I activate the “Split Screen View” in the preview window (set to FX Bypassed) the original contrast shows through. It is as if I applied an FX even though it is not the case.
    More confused than before….
