Activity › Forums › Adobe After Effects › Continuous Rasterization on ai file
  • Continuous Rasterization on ai file
    Posted by Abbi Eiler on November 12, 2020 at 4:35 pm
    I have a row of ornaments animated where 1 drops and then rotates to show words on the other side. There is also a 1-node camera zoom from-2666 into -946 and then back out to -1506 where it stays for the rest of the video. The ornaments are png files. Once the ornament zooms in the words get blurry. So to fix this I got svg files of the ornament and converted it in ai. When I replace the png with the new ai ornaments it is still blurry. If I do the continuous rasterization toggle then a white rough outline pops up around the ornament and it slightly moves and it STILL doesn’t make the text stay crisp. Please help!
    Eric Santiago replied 5 years, 10 months ago 3 Members · 2 Replies
  • Ryan Hauser
    November 12, 2020 at 7:38 pm
    Continual rasterization can be a pain in the neck at times. There’s lots of stuff it doesn’t like to play well with, so it’s hard to pin down exactly what your issue might be based on the description. My first guess would be that you have a layer-style based stroke on the ornament, but that’s just a guess. Can you post a screenshot of the visual error you’re describing?
  • Eric Santiago
    November 13, 2020 at 12:36 am
    Are you using a 3D Camera?
    Maybe some kind of DoF issue?
