Activity › Forums › Adobe After Effects › Continuous Raster and 3D Rotation at the Same time in a Precomp?
  • Continuous Raster and 3D Rotation at the Same time in a Precomp?
    Posted by Brent Taylor on April 6, 2014 at 12:43 pm
    Hey guys. Consistently getting a glitch and wondering if there is a solution.
    When I’m using a precomp (specifically, a set of character hands which are then used with Time Remapping in the main comp) I can’t get both Continuous Raster and 3D rotation at the same time.
    If I try to use both, the bounding box does 3D rotation, but the contents do not. They don’t show up in the render, either.
    If I turn off Continuous Rastering, it works as normal. But then of course it ends up looking like garbage.
    I tried the same thing in AE CS6 to see if it was just a version thing (I primarily use CS4). Same thing.
    Help?
    Brent Taylor replied 12 years, 5 months ago 2 Members · 2 Replies
  • Brian Charles
    April 6, 2014 at 4:54 pm
    Do the layers in the PreComp have the 3D switch enabled?
    Here is an example with a nested Composition with CR (actually CT) and 3D rotation.
    7330_box.aep.zip
  • Brent Taylor
    April 7, 2014 at 2:25 am
    Oh, sweet… yeah, that did it. Thanks so much! Surprised I didn’t think of that.
    By the way, are there any guidelines on which posts belong in the regular After Effects forum and which go in the Basics forum? I’m never sure.
