Activity › Forums › Adobe After Effects Expressions › Continuous bounce
  • Posted by Kostas Bartsokas on May 15, 2014 at 7:14 pm
    Hi to all.
    I am quite new to expressions. I am creating an animation with a sign hovering over a persons head. I want the sign to bounce continuously (with Inertia) and perhaps rotate a bit to either side. I have found the Inertia Bounce expression but I couldn’t get it to work, cause it always stops after a few bounces.
    Could anyone help?
    Thanks in advance.
    K.
    Kostas Bartsokas replied 12 years, 4 months ago 2 Members · 3 Replies
  • Kevin Camp
    May 15, 2014 at 8:33 pm
    for position you could use something like this:
    freq = 1; //bounces per second
    amp = 100; //bounce height in pixels
    y = Math.sin(time*Math.PI*freq)*amp/2;
    value + [0,y]
    it will cause a layer to continually bounce in an elastic fashion.
    if you needed a hard bounce (like a ball bouncing off the ground), you could change the third line to this:
    y = Math.abs(Math.sin(time*Math.PI*freq))*amp;
    for rotation, since you could use the same expression but change the last line to this
    value + y
    Kevin Camp
    Art Director
    KCPQ, KZJO & KRCW
  • Kevin Camp
    May 15, 2014 at 8:34 pm
    also, if you want more info on expression like these, you can find more on them at motionscript.com.
    these were based on the expression found here:
    https://www.motionscript.com/mastering-expressions/simulation-basics-3.html
    Kevin Camp
    Art Director
    KCPQ, KZJO & KRCW
  • Kostas Bartsokas
    May 16, 2014 at 6:19 am
    Hi Kevin
    it worked like a charm!! Thank you very much! I’ll have a look at Motionscript.
  • Viktor Vaughn
    January 5, 2021 at 3:27 pm
    Hi Kevin,
    Is there any way to randomise the freq or amp to parimeters i can set?
    Much appreciated
