Activity Forums Adobe After Effects continued problems with calendar using expressions
  • continued problems with calendar using expressions
    Posted by Olly Bea on July 20, 2005 at 1:23 pm
    to anyone who can help or Filip Vandueren, I am still having problems trying to make this year-long calendar with day counter…
    Here is the expression I have put in:
    dateValue=thisComp.date 2;(“Layer with Numbers effect”).effect(“Numbers”)(4); // change the layerName
    startValue=1; // the Slider-value at which you want the day counter to be 1
    days=180; // number of days you want to count
    dayCounter=linear(dateValue, startValue-1, startValue+days-1,0, days)
    the layers name is called: date 2
    Any idea why the expression is not working?
    Filip Vandueren replied 21 years, 2 months ago 3 Members · 2 Replies
  • Mylenium
    July 20, 2005 at 6:27 pm
    It’s screwed. Try this:
    dateValue=thisComp.layer(“Numbers”).effect(“Numbers”)(4); // change the layer name
    startValue=1; // the Slider value at which you want the day counter to be 1
    Mylenium
    [Pour Myl
  • Filip Vandueren
    July 21, 2005 at 11:01 pm
    the first line should be:
    dateValue=thisComp.layer("date 2").effect("Numbers")(4); // change the layerName
    The name has to be in the brackets and quoted.
