Activity Forums VEGAS Pro continue rendering image sequence in Vegas Pro, but how?
  • continue rendering image sequence in Vegas Pro, but how?
    Posted by René Van gageldonk on April 20, 2013 at 3:37 pm
    I’ve stopped a rendering of an tiff image sequence half way in Vegas Pro. I’d like to continue the rendering but can’t find a way to switch on the continual serial sequence. It starts over at filename_0000000.tif but I obviously would like to continue with the number where it left of. Any ideas on how to do this?
    René Van gageldonk replied 13 years, 5 months ago 2 Members · 2 Replies
  • John Rofrano
    April 20, 2013 at 5:05 pm
    Since this is not possible, I would render the rest to a new folder then use a utility like Bulk Rename Utility to rename the files to start where the others left off. That should work.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • René Van gageldonk
    April 20, 2013 at 5:32 pm
    That’s what i’m doing now.
    It is common for renderengines to be able to do this;.. after effects, 3Ds max etc all give the option of “skip existing frames”. That way more machines than one can be used to render a sequence.
    This is a missed opportunity of Vegas.
    thanks for your answer.
