Activity › Forums › Adobe After Effects › continue evolution through multiple compositions
  • continue evolution through multiple compositions
    Posted by Miro Nauces on June 23, 2017 at 2:44 pm
    I have more compositions, all of them use a precomp with solid layer and some evolving color effects on it. What I need is to have the effect to progress in each following composition. Now the effect just starts from beginning with every composition.
    I tried to set up effect controls on main composition and automate there, but the result is same.
    Is there any simple solution to this? Thank you.
    Miro Nauces replied 9 years, 3 months ago 2 Members · 3 Replies
  • Michael Szalapski
    June 23, 2017 at 4:28 pm
    Make your source precomp longer and then just offset the time of its layer in each of the comps that use it.
    – The Great Szalam
    (The \’Great\’ stands for \’Not So Great, in fact, Extremely Humble\’)
  • Miro Nauces
    June 23, 2017 at 4:38 pm
    this is what I try to avoid. I know I can manually move the precomp in each separate composition som it would match but everytime I change the length of the compositions, I would need to adjust the whole thing again.
  • Miro Nauces
    June 23, 2017 at 4:55 pm
    Just a quick idea – could I use some expression that sets the start of the precomp to the actual time on the main composition? This way I would not need to manually adjust it.
