Activity › Forums › Panasonic Cameras › Contents Folder
Contents Folder
Posted by John Paluzzi on May 27, 2008 at 6:53 pmWhen I offload my P2 footage onto a drive, sometimes the contents folder has the “lock” symbol and sometimes it doesn’t. Anyone else experience this?
D. scott Dobbie replied 18 years, 4 months ago 3 Members · 4 Replies -
D. scott Dobbie
May 28, 2008 at 10:52 pmHaven’t heard of this myself. Can you duplicate this? How are you offloading? (i.e. through a PowerBook G4; using a Dual Adaptor with a MacBook Pro; etc.) If you’re using a Mac, have you tried repairing the permissions using Disk Utility? Can you unlock the folder?
John Paluzzi
May 29, 2008 at 2:38 amYes, it did it again today. I’m using MBP OSX 10.5.2 with a Duel Adapter using HD Log Gold to offload (Dan sent me a temp version that works with 10.5.2 that doesn’t crash the system!)
Maybe that is the issue…I’ll see when the final update of HD Log comes out and try again. All the footage seems to be there, but the contents folder does not have the lock. If I go into properties, I’m able to lock it….very strange.
HPX-2000 w/AVC board
P2 Mobile with AVC board
MBP 10.5 -
Todd Reid
May 29, 2008 at 2:29 pmI have noticed the lock sometimes, but it has never interfered with the import into FCP.
Do the cards have a lock function like a cassette?
I used to call this the idiot button, cause on a 3/4″ tape it was on the bottom and easy to forget about. -
D. scott Dobbie
May 29, 2008 at 6:01 pm[todd reid] “Do the cards have a lock function like a cassette?”
Yes, the cards can be locked by flipping a little switch on the end. For safety, you want to lock the cards whenever you’re downloading footage. But that lock wouldn’t affect the results of the download – only prevent anything being written back to the card. You’d need to unlock the card before reformatting it or, if using a computer, dragging items to the trash and emptying it.
