Activity Forums Apple Final Cut Pro Legacy content slip within FCP timeline’s Motion template’s drop zones
  • content slip within FCP timeline’s Motion template’s drop zones
    Posted by Edward Kulzer on October 1, 2009 at 5:31 pm
    Within a FinalCut 7 standard SD NTSC timeline, using a Motion master Template with 2 drop-zones, I set I/O marks on the 2 master clips intended for the drop zones, & drag the thumbnails to their respective spots within the template Control.
    Only: The content slips, and the I/O marks are not respected.
    The timelines we’re dealing with here are rather long-form: 60 – 90 minutes, but for what had been intended to be method to simplify rather simple “drag & drop” work, due to the slippage resulting in out of sync issues, the template’s proving to be an annoying albatross.
    There does not seem to be a method to slip the drop-zones’ content within their control panel.
    Could anyone shed some light on the issue?
    Edward Kulzer replied 16 years, 11 months ago 2 Members · 2 Replies
  • John Pale
    October 1, 2009 at 5:54 pm
    Not sure what is causing it, but how about exporting the portions you want to use as self-contained Quicktimes (same codec as source) and then using those on the drop zones instead.
  • Edward Kulzer
    October 1, 2009 at 6:42 pm
    Definitely worth trying out; using subclips of solely the In to Out (even carefully matching the durations to the specific duration of the Master template in the timeline) didn’t work.
