Activity › Forums › Maxon Cinema 4D › Constraining the vibration tag
  • Constraining the vibration tag
    Posted by Stephen Moore on January 5, 2019 at 4:32 pm
    Hi All,
    I’m building a clown’s car, which needs to look old and decrepit. The SSs below shows just the engine block with an old fashioned bonnet or hood door that pivots from the top, out and up. I’d like this door to pivot randomly as it moves. I’ve added a vibrate tag, which almost does the job.
    The door at rest is here…
    And it bounces out to here…
    However it rotates back into the engine block here…
    Is there a way to constrain the vibration between the rest position and the second SS or is there another solution?
    Ignore the Connector, it’s not linked to anything.
    Many thanks
    Stephen
    Stephen Moore replied 7 years, 8 months ago 1 Member · 0 Replies
  • 0 Replies
