Activity › Forums › Apple Final Cut Pro Legacy › Constantly Rendering
Posted by Kyle Ferris on January 30, 2011 at 4:13 pmI’m working on an HD Proj for the first time. I have some experience with FCP but only SD. The FCP version is a little older (5.1.4) but is handling HD footage just fine. (I’m not ready to spend the money on an Intel Mac just yet). The trouble I’m having is when simply dragging a selected portion of a clip from the Viewer to the time line, I have to render it to play it back. I don’t recall having to do this in the past. I can understand if I changed the clips speed or applied a filter or effect, but should I really have to render it if it’s just a raw clip?
I’m hoping it’s just a setting somewhere. Any suggestions?Thanks
Jeff Greenberg replied 15 years, 7 months ago 4 Members · 6 Replies -
David Roth weiss
January 30, 2011 at 6:13 pmWhat variety of HD footage are you editing, and what type of media drives is your video residing in and playing from?
Constant rendering typically is indicative of sequence settings and media type not matching.
David Roth Weiss
Director/Editor/Colorist
David Weiss Productions, Inc.
Los Angeles
https://www.drwfilms.comPOST-PRODUCTION WITHOUT THE USUAL INSANITY ™
A forum host of Creative COW’s Business & Marketing and Apple Final Cut Pro forums. Formerly host of the Apple Final Cut Basics, Indie Film & Documentary, and Film History & Appreciations forums.
Kyle Ferris
January 30, 2011 at 6:40 pmI’m working with HDV footage and .tif photo files and I’m saving it all to a removable 500GB, CalDigit SATA RAID drive.
Thanks for the response
Shane Ross
January 30, 2011 at 9:09 pm#28 Having to render every clip in the timeline
Shane’s Stock Answer #28: When I put a clip in the timline, I have to render it before it will play. Why?
Your clip settings MUST match your timeline settings. If you have DV/NTSC material, you need a DV/NTSC timeline. The frame rate, audio rate and dimensions (4:3, 16:9) all need to match exactly. In Final Cut Pro 6, this is easy, because when you drop a clip into the timeline, it asks if you want to set up the timeline to match the settings of the first clip you drag into it. Click YES and you are ready to go.
However, in FCP 5.1 and earlier, it is a bit trickier.
The most important thing you need to do is properly set up your project from the start, and the best way to do this is to choose a setting from the Easy Setups, located under the Final Cut Pro menu.
Once you do this, you’ll need to create a new sequence. This is because the sequence that is already in your new project is setup for the typical default setting of DV/NTSC, or for the settings of your last project, which might not match what you are currently working with. So delete SEQUENCE 1 and create a new sequence:
This new sequence will contain the settings you chose in the Easy Setup menu, and should match the format you captured.
Shane
Read my blog, Little Frog in High Def -
Jeff Greenberg
January 30, 2011 at 10:44 pmIt sounds like a mismatch between your timeline and your raw (video) clip.
I can’t recall if it was FCP 5 or 6 where FCP would automatically ‘switch’ the timeline to match the footage on the VERY FIRST clip to hit the timeline. Try this method first:
Create a new timeline (nothing special), drop a video clip into it…and it should offer to switch the timeline to match.If not? We need the timeline and the video clips to match
Hit CMD-Shift-N; and FCP will give you every type of timeline you can create.
I’ll assume it’s a HDV 1080i 29.97 (Pick that.) If you drop footage in it, it should just ‘work’ if it was matched correctly.Best,
Jeff G
Apple Master Trainer
Avid Cert. Instructor DS/MC
Avid & Color Videos Vasst.com
Compressor Essentials Lynda.com -
David Roth weiss
January 30, 2011 at 11:42 pm[Jeff Greenberg] “I can’t recall if it was FCP 5 or 6 where FCP would automatically ‘switch’ the timeline to match the footage on the VERY FIRST clip to hit the timeline.”
Sorry, but that came our way in Ver. 6.
David Roth Weiss
Los Angeles
Jeff Greenberg
January 31, 2011 at 2:05 am[David Roth Weiss] “Sorry, but that came our way in Ver. 6.”
Don’t be sorry! Collective memory and all that!Best,
Jeff G
