Activity Forums Adobe Premiere Pro Constantly conforming, loading media
  • Constantly conforming, loading media
    Posted by Warren Morningstar on August 21, 2009 at 7:02 pm
    Every time I open an existing project in CS4, it first loads the media and conforms audio. Didn’t used to do that. Any ideas what I need to check?
    Thanks for the help.
    Warren
    Warren Morningstar replied 17 years ago 3 Members · 6 Replies
  • Brian Louis
    August 21, 2009 at 9:08 pm
    Are you using external drives?
  • Warren Morningstar
    August 21, 2009 at 9:21 pm
    Nope – Raid 0 striped array internal. I’m wondering if it’s a media cache thing.
  • Vince Becquiot
    August 21, 2009 at 10:40 pm
    Yes try moving/renaming the media cache folder. Are you on Vista?
    Vince Becquiot
    Kaptis Studios
    San Francisco – Bay Area
  • Brian Louis
    August 21, 2009 at 10:47 pm
    It could be, where are you storing the cache files and cache database? usually the location is listed under “Edit/Preferences/Media” in a “Common” directory used by other Adobe Apps, maybe the directory doesn’t exist and its dumping them somewhere else.
  • Brian Louis
    August 21, 2009 at 11:57 pm
    Side note: the AppsData directory listed in the paths in the Media pane is a hidden directory, Like Vince mentioned sometimes you have to move it elsewhere. I have a second disk which I keep housekeeping data, preview files and other esoteric files on, so they are off the Apps drive.
    August 31, 2009 at 7:09 pm
    Thanks for the response. Was in Santa Monica last week for a shoot with Harrison Ford (name dropping shamelessly) last week. Back to messing with the box.
    When you say a different drive for housekeeping, are you suggesting a third drive? I currently have the Adobe apps on the C drive with the OS, and a RAID 0 drive I use for project files, assets, and the housekeeping files.
