Activity › Forums › Apple Final Cut Pro › Consolidating several audio angles within a multicam sequence
  • Consolidating several audio angles within a multicam sequence
    Posted by Brian Thomas on March 24, 2018 at 2:51 pm
    Say I have just created a multicam clip with several camcorders and a whole lot of short audio clips. Each (non-overlapping) audio clip has been assigned it’s own ‘angle’ so I’m having to page up and down to adjust volume etc.
    How can I get all those small audio track easily onto one angle? I’ve tried pressing shift as I drag them onto the same angle and sometimes this works perfectly but other times they jump around a bit. Perhaps I shouldn’t be using shift? Is there another key/combination I should be using to drag them into their equivalent position on one particular angle? Thanks in advance.
    FCPX and PPro 6. iMac 24 + MBP 15″. Near Geneva, Switzerland
    Brian Thomas replied 8 years, 6 months ago 2 Members · 2 Replies
  • Bill Rabkin
    March 26, 2018 at 2:41 am
    Rather than dragging-and-dropping, you might want to try copy-and-paste. That should let you position the Playhead exactly where you want to “drop” the clip, and paste it right there.
    Bill
    FCPX 10.4
    iMac 27\” Retina 2017
    macOS 10.12.6 Sierra
  • Brian Thomas
    March 26, 2018 at 5:43 am
    Oh yes, thanks Bill, I’ll try that.
