Activity Forums Avid Media Composer Consolidate media from in and out points?
  • Consolidate media from in and out points?
    Posted by Sean Lennon on May 10, 2022 at 11:28 am
    Hi, is it possible to consolidate media that is associated only with the in and out points I set in a sequence?
    Cheers
    S
    Sean Lennon replied 4 years, 1 month ago 2 Members · 2 Replies
  • Pat Horridge
    May 10, 2022 at 11:35 am
    Yes ensure the tracks you want to work with are enabled (and those you don’t want are disabled.
    Mark your sequence In and Out. Drag the clip icon in the top right of the record window to a bin to make a sub sequence. You can then consolidate that sub sequence.
  • Sean Lennon
    May 10, 2022 at 11:37 am
    Ah yes, great, thank you.
