Activity › Forums › Apple Final Cut Pro Legacy › Consolidate from FCP TO XDCAM disk
  • Consolidate from FCP TO XDCAM disk
    Posted by Sarah Bright on February 1, 2011 at 5:50 pm
    I’ve been given a list of deliverables for end of edits coming up soon and one is a Consolidate To XDCAM Disk.
    I’ve tried all obvious options to do this, media manager to disk, export to disk, drag and drop, xdcam transfer ‘Add Source’ and haven’t had any luck.
    Is this even possible?
    Sarah
    Sarah Bright replied 15 years, 8 months ago 2 Members · 2 Replies
  • Victor Perez
    February 1, 2011 at 9:05 pm
    Do you mean export your sequence to Disk via firewire?
    If so…
    Sequence Audio must be set to either 2 or 4 channel MONO
    and each track needs to be routed to its appropriate output.
    Victor
    http://www.editvictor.com
    http://www.hbhm.tv
    http://www.itvisus.com
  • Sarah Bright
    February 2, 2011 at 12:50 am
    I tried that… It just made an mxf vlc and xml on the disk.
    You know when you do a consolidate, i.e, media manage to a hard drive you have a consolidate that is just the media used in the sequence… well, they want that but on an XDCAM disk instead of on a drive (save storage space apparently). I PRESUME it’s do-able since my client has requested it.
    I did a google and searched on here but no luck.
    Sarah
