Activity Forums Apple OS X Connectivity problem from 2 PCs to my IMac and Router
  • Connectivity problem from 2 PCs to my IMac and Router
    Posted by Barry Lee on February 5, 2011 at 6:38 pm
    I know this is a long explanation but I’m trying to lay the problem out clearly.
    -I have been accessing the internet wirelessly with my iMAC desktop and two PCs in my home for about a year now, via a cable company modem and an Apple AirPort router.
    -A recent storm was the culprit in causing me to lose the internet by playing havoc with the modem through the cable company’s downed lines, et al.
    -Since then, the modem (a Motorola SURFboard) has been reset by the cable company and confirmed by the cable company to be operating perfectly.
    -The AirPort (Version 7.5.2) is also operating correctly.
    Here is the problem:
    Both my PCs (one with a wireless card and the other with a Netgear usb device are showing strong signals but no connectivity. For some reason unbeknownst to me, they are not acquiring the IP address of the iMac and Router serving the network. My connection to the internet from the iMac is working flawlessly, but the PCs are not recognizing it.
    What can I do to make this work?
    Barry Lee replied 15 years, 7 months ago 4 Members · 13 Replies
  • 13 Replies
  • Zane Barker
    February 6, 2011 at 9:47 pm
    Do any of the computers connect to the internet when directly connected to the cable modem via Ethernet?
    **Hindsight is always 1080p**
  • Barry Lee
    February 7, 2011 at 3:39 am
    Only the iMac connects to the internet via the modem and wireless router. The two PCs are supposed to connect through the router. Both PCs show a strong signal but no connectivity; they do not acquire the IP address that will make them connect.
  • Barry Lee
    February 7, 2011 at 3:42 am
    Only the iMac connects to the internet via the modem and wireless router. The two PCs are supposed to connect but show only a strong signal but no connectivity. It shows that they are not picking up the IP address.
  • Zane Barker
    February 7, 2011 at 7:40 am
    I’m not asking about the wireless router. For what I’m asking disconnect it and set it aside.
    Do the computers connect to the internet when connected directly to the cable modem via a ethernet cable?
  • Barry Lee
    February 7, 2011 at 1:50 pm
    That was a very good question. I connected the cable directly to one of the PCs and received the same error message that it was unable to locate the IP address. What does that tell you?
  • Zane Barker
    February 7, 2011 at 2:41 pm
    If you still cannot connect when plugged in directly the it is most likely not the wireless router.
    It is one of 3 things a bad Ethernet cable, a problem with the cable modem, or a problem with the Internet provider.
    Try it again directly connected but with a different Ethernet cable if it still does not work then call your Internet provider and tell them they were wrong as you still cannot get on the Internet when directly connected to the cable modem.
  • Barry Lee
    February 7, 2011 at 5:00 pm
    I’ve been online all this time on the iMac through the router. However, I disconnected the Ethernet cable from the wireless router and went directly from the cable company modem to the iMac computer to test the cable. It didn’t work.
    Just to confirm that the cable was at fault, I rebooted the modem. Then the connection to the internet was successful.
    I then unplugged the Ethernet cable from my iMac and plugged it into each of the PCs and tried to get online. I couldn’t.
    Does this still indicate that the Ethernet cable is at fault?
    I’m typing you this message online, on my iMac, with the Ethernet cable hooked up directly from the modem.
    With this in mind, It’s hard for me to understand how the Ethernet cable or the modem could be at fault, but I will go out and purchase an Ethernet cable if you still feel that it’s the culprit.
    I appreciate your patience in this and will do whatever is necessary to get this problem solved.
  • Zane Barker
    February 7, 2011 at 5:10 pm
    [Barry Lee] “I’ve been online all this time on the iMac through the router”
    REALLY, you should have said that in your first post.
    At this point, you should really have someone come look at it in person. Trouble shooting something like that over the internet is extremely hard, especially when I have to drag info out that should have been included original post.
    Again have someone come look at it in person.
  • Barry Lee
    February 7, 2011 at 5:17 pm
    I was very clear about this from the first line of my very first post. However, I do thank you very much for your time and will do what you suggest. I’m thinking that with everything that has been going on, that the router might be the problem and merely operating as a conduit rather than functioning as a router, if that makes any sense. Again, thanks for your time.
  • Jerry Jorgenson
    February 7, 2011 at 7:53 pm
    The first thing to find out is if you can get from the iMac to the PCs. Open a terminal window and do a traceroute. It should look something like this:
    (nekokun is a system on the local network)
    $ traceroute nekokun
    traceroute to nekokun.j3issint.com (192.168.1.113), 64 hops max, 52 byte packets
    1 nekokun.j3issint.com (192.168.1.113) 0.864 ms 0.285 ms 0.196 ms
    If you can’t get there, then there may be something wrong with the PC network cards or routing on the PCs. You’ll have to use the network control panel to figure out what.
    If that works try pinging something outside the network from the PC also try pinging your iMac.
    $ ping https://www.creativecow.com
    PING https://www.creativecow.com (64.71.189.236): 56 data bytes
    64 bytes from 64.71.189.236: icmp_seq=0 ttl=54 time=54.098 ms
    64 bytes from 64.71.189.236: icmp_seq=1 ttl=54 time=53.943 ms
    64 bytes from 64.71.189.236: icmp_seq=2 ttl=54 time=53.976 ms
    If that doesn’t work, check the firewall settings (if any) on the router.
