Activity Forums Apple OS X Connection iMac and external HDD Mybook WD 4 TB
  • Connection iMac and external HDD Mybook WD 4 TB
    Posted by Zeljko Tomic on December 6, 2010 at 1:07 pm
    I have iMac and I’m using it to runn Final cut pro. I have connected Mybook WD HDD 4 TB trough firewire and I use it as a scratch disc. Everything was working OK last 3 months and today I have trouble opening the Final Cut project from Mybook. It runs very slow and it takes more then 20 min. to open the project. Imac has 8 Gb of RAM and 2.4 quadcore Intel processor, so resources are not he problem. On Mybook I have little more then 1 TB of material. Sometimes OS doesn’t recognize Mybook at all.
    I did OS software update for iMac.
    What could be the problem, any ideas?
    Zane Barker replied 15 years, 8 months ago 2 Members · 3 Replies
  • Zane Barker
    December 6, 2010 at 4:26 pm
    Fitst thing run disk utility on the drive, better yet run disk warrior on the drive.
    **Hindsight is always 1080p**
  • Zeljko Tomic
    December 28, 2010 at 2:08 pm
    I tried, but it doesn’t work. Mac freezes when I try to run Disk Warrior software. Repair function in the disk utility didn’t work, repair failed. What ever I do, computer freezes. Updating firmware is not possible also.
    Sometimes My Book isn’t recognized by mac, and if I get the icon on desktop, disk looks empty. Info shows that there is 1,9 TB material, but there is nothing on disk.
    I connected it on mini-mac, no improvement.
    How can I save data on this disk?
  • Zane Barker
    December 28, 2010 at 3:56 pm
    Looks like your your going to need to send the drive to a data recovery specialist, like Drive Savers. But be prepared, because it may cost you a pretty penny.
