Activity Forums DaVinci Resolve Connection for HP Dreamcolor monitor
  • Connection for HP Dreamcolor monitor
    Posted by Ergin Ozturk on December 17, 2012 at 12:24 pm
    I’ve just purchased HP Dreamcolor as grading monitor for my DavinciResolve suit.
    Although i read lots of article & forums i could not find the clear answer for the connection yet:
    I have MacPro with following cards;
    1-Nvidea Quadro 4000 (for GPU) – (output: Displayport)
    2-Nvidia geforce gt 120 (fori GUI)
    3-Decklink HD Extreme 3D – (outputs: HD-SDI and HDMI output)
    4-(external) HDLink Pro with DVI-D (outputs: DVI-D) – for my ex grading monitor AppleCinema display
    my question is;
    to use Dreamcolor’s 10 bit feature what kind of connection should i use?
    a-Quadro4000 DisplayPort ->Dreamcolor Display port ?
    b-Decklink HD Extreme HDMI ->Dreamcolor HDMI ?
    c-HDLink Pro with DVI-D -> Dreamcolor DVI?
    d-or any other?
    thanks in advance.
    //ergin
    Javier Martos valladares replied 13 years, 7 months ago 6 Members · 8 Replies
  • 8 Replies
  • Paul Jay
    December 17, 2012 at 5:50 pm
    Hdp2 or hdlink pro
    HdSdi from decklink
  • Robert Houllahan
    December 17, 2012 at 8:13 pm
    I would recommend the AJA converter as it has modes to use deep color on the HP and is less expensive. Unfortunately the HD-Link Pro Display Port has a problem where it distorts 3D LUTs that are loaded into it making it practically unusable until BMD fixes the problem.
    -Rob-
    Robert Houllahan
    Director / Colorist
    Cinelab Inc.
    http://www.cinelab.com
    MAHC-PRO 6-Core 3X GTX285 20Tb SAS Wave Panel Panny 11UK SDI Plasma. Light-Space CMS + Hubble
  • Juan Salvo
    December 17, 2012 at 11:02 pm
    Or you could just not use a lut on it.
    Colorist | Online Editor | Post Super | VFX Artist | BD Author
    https://JuanSalvo.com
  • Eric Sternberger
    December 18, 2012 at 2:04 pm
    when you have to buy the aja Hi 5 for connections, the dreamcolor is in the same price-range as a FSI-Monitor, which is a “real” monitor. Is the color-reproduction on the HP so much better to justify spending my money on it anyway?
    I think a lot of you guys have seen both. so how do they compare? (color-wise)
  • Eric Sternberger
    December 18, 2012 at 2:31 pm
  • Robert Houllahan
    December 18, 2012 at 10:35 pm
    I tried to use the Decklink-Pro Display Port without a LUT and either with connection to HDMI or as a SDI pass-through it changes the picture… so until they fix it I consider it a $700.00 paperweight.
    -Rob-
    Robert Houllahan
    Director / Colorist
    Cinelab Inc.
  • Juan Salvo
    December 19, 2012 at 5:49 am
    [Eric Sternberger] “he dreamcolor is in the same price-range as a FSI-Monitor, which is a “real” monitor. “
    This is a really good point. The dreamcolors are also notoriously flaky. And just frankly not a very good choice.
  • Javier Martos valladares
    January 16, 2013 at 9:44 pm
    The dreamcolor monitor entine needs a true RGB 4:4:4 signal vía display port so it’s a bit dificult to configure.
    Allan Tepper has a lot of info about that issue in provideo coaliton web.
    I was planning on buying one but maybe an FSI is more compatible, but the 10bit model FSI is more expensive.
