Activity › Forums › AJA Video Systems › Connecting to my Plasma TV?
Posted by Steve Price on January 29, 2009 at 1:49 pmHello,
I’m using the Kona LHe with the breakout rack – love it, wonderful piece of kit – but I currently have it connected to my TV via the composite input. The TV is a PAL HD 42″ LG with every connection known to man (inconveniently placed around the back of course!)and I’d like to know how to connect my card to it via the HDMI connector so I can watch my edits in proper HD.
I have to say this TV is not very impressive when connected with a composite phono cable, so I’m hoping I can better results another way.
I’m editing on a Mac Pro running FCP and I have 8Gb RAM and 2 x 3.2GHz Quadcore processors and 2 x NEC LCD Widescreen monitors.
Steve.
Tim Ward replied 17 years, 7 months ago 7 Members · 11 Replies -
Joseph Borruso
January 29, 2009 at 2:49 pmYou need to get an SDI to HDMI converter. AJA has one. It is called a Hi5
https://www.aja.com/html/products_converters_HI5.htmlI have one and it works great.
Stuart Simpson
January 29, 2009 at 5:05 pmCan’t you just feed it the component signal from your LH?
-Simmie
6 MacPros – Kona 3 & Kona LH
1 G5s – Kona LH
xbox360, Wii, PSP, PS3
https://www.speak.co.uk -
Steve Price
January 29, 2009 at 5:10 pmI guess so, but that’s still analogue, I was wondering how to keep everything digital all the way through the system.
Thanks for your suggestion though,
All the best,
Steve. -
Tim Ward
January 29, 2009 at 6:53 pmDigital or analog, it’s still not going to be a reliable display for accurate, critical production. That’s what professional displays are for. You wouldn’t use your analog living room CRT TV for professional production, even if it does have those nice Y’Pb’Pr inputs. You’d use a professional/broadcast monitor. It just depends on what kind of production you’re doing, and how accurate of an image you want to look at. It may suit you fine if you’re off-lining or doing DVD/BD stuff, but not really for broadcast on-lines.
James Reid
January 30, 2009 at 1:14 amBut note that AJA has this to add:
“The Hi5 does not encode the HDMI output with HDCP encryption.
By definition, SDI/HD-SDI inputs to the Hi5 are unencrypted.
The HDMI specification requires HDMI monitors to support unencrypted inputs.”
Many consumer HD TV sets only accept Hi-def 1080p when it is HDCP encrypted. Some others will accept unencrypted. The manual for the set will tell you.
Check it out first before you buy the Hi5 -
Christopher Tay
January 30, 2009 at 2:33 amSome places I’ve been to have consumer monitors in the edit suite, in addition to the professional monitors as the editors wants to see how the images would look like on a consumer monitor. It’s not a real representative of what we end up seeing at home coz what we see at home are MPEG compressed images but some would argue that one should also see how the images look like, especially when grading is involved, on a consumer monitor to get a gauge.
What say you ?
-chrispy
PS : I see Bob on the way…
Walter Biscardi
January 30, 2009 at 11:34 am[Steve Price] “I guess so, but that’s still analogue, I was wondering how to keep everything digital all the way through the system. “
That’s all we do here. We have three HD suites with three Panasonic Pro Plasmas. All are fed via Component from our AJA Kona 3’s. Image is pristine with no additional cost.
Only the BluRay players feed the screens via HDMI.
Walter Biscardi, Jr.
Biscardi Creative Media
HD and SD Production for Broadcast and Independent Productions.STOP STARING AND START GRADING WITH APPLE COLOR Apple Color Training DVD available now!
Walter Biscardi
January 30, 2009 at 11:36 am[Christopher Tay] “What say you ? “
I’ve always felt that’s a good idea. We don’t have room anymore for consumer tv’s in our rooms, but if you have the room, it’s not a bad idea.
Of course, these days with such high quality LCD and Plasma screens out there, that’s becoming a moot point.
Tim Ward
January 30, 2009 at 2:36 pm[Christopher Tay] “at say you ?”
Completely agree. It’s like after you’ve just mixed that awesome soundtrack for a new program, and then playing it through your internal computer speaker to hear how it translates in lo-fi situations. But I still use the nice studio monitors for mixing. 🙂
