Activity › Forums › Apple Final Cut Pro Legacy › connecting separate video and audio tracks
  • connecting separate video and audio tracks
    Posted by Ben Hawkins on April 19, 2010 at 2:42 pm
    We shot some interviews with the audio being recorded as a separate then the video. Is there anyway i can treat them as one for sub-clipping with out exporting them out as a quicktime and bringing them back in.
    Shane Ross replied 16 years, 5 months ago 3 Members · 3 Replies
  • John Fishback
    April 19, 2010 at 3:05 pm
    The audio must be PCM 16 or 24 bit, 48kHz. If it’s not, use an app other than FCP (Soundtrack Pro, QT Pro, etc.) to convert the audio to those parameters. Then import the audio into FCP. Lay it against the video and sync the two. Then highlight the synced video and audio tracks and hit Cmd L. That will link them together.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 3 (FCP 7.0.2, Motion 4.0.2, Comp 3.5.2, DVDSP 4.2.2, Color 1.5.2)
  • Ben Hawkins
    April 19, 2010 at 3:17 pm
    awesome, was not aware that once you linked the clips fcp would keep them linked after you sub-clip.
    thanks again
    I got the hottest beats and the softest fur.
  • Shane Ross
    April 19, 2010 at 4:33 pm
    Are there slates? Find the common in point, mark IN on both, then use the Merge Clips command. This makes a new clip with audio and video tied.
    Shane
