Activity › Forums › Apple Final Cut Pro Legacy › Connecting external computer to iMac using Final Cut
  • Connecting external computer to iMac using Final Cut
    Posted by Mark Jackson on August 9, 2011 at 4:19 pm
    Greetings all:
    How do I connect an external computer monitor to my iMac to use as a client Monitor for Final Cut Pro 7?
    Any tips for would be greatly appreciated.
    Mark D. Jackson
    Dennis Leppell replied 15 years, 1 month ago 4 Members · 3 Replies
  • Shane Ross
    August 9, 2011 at 7:31 pm
    You don’t. Not unless it is a very specific iMac:
    https://support.apple.com/kb/ht3924
    Shane
  • Andrew Evans
    August 9, 2011 at 9:21 pm
    You need a display port adapter to which ever connection your monitor uses (vga, dvi). In final cut: view -> video playback. Or you could use external video, which uses firewire through a dv camera. Hook the camera up to a tv using rca cables.
    Andrew Evans
    Lake TV
    iMac 2.5G Quad 8GB
    FCS 3
  • Dennis Leppell
    August 10, 2011 at 6:10 pm
    I just saw a product announcement that breaks out the thunderbolt port to two HDMI ports….think it was apple branded, so maybe look into that.
